steering shock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Sep 19, 2001.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    have a question about the steering shock for lack of what it really is called. it leaks what looks like antifreeze. does this mean i need to change it. and if it does is at simple as it looks and which would be a good replacement
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Its called a steering stabalizer. If its leaking you should replace it. There are two types of stabalizers, dual and single. a dual is for 36" and lager tires and the single is for 35" and smaller. There are a few different people who make them. you can get a new rancho unit for $50 for the single and $100 for the dual
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Are you sure that the fluid that looks like coolant isn't actually COOLANT? It almost sounds like you have a leak in your rad that is dripping down onto your steering stabilizer. Before you go and buy a new stabilizer you should rule out rad trouble.........
    <font color=blue> WE WILL NEVER SURRENDER<font color=blue>
  4. KENNY
    Dec 7, 2000
    292
    nyc
    i've double and triple checked, it drips on the passenger side of the shock. looked up and down and couldn't see any other leak from anyplace else. does this happen when the stabilizer goes bad? I HAD recently replaced it about 8mos ago, before i decided to do all well some of my mechanic work myself.
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It sounds to me like it's sprung a leak - I would look into upgrading to an aftermarket replacement, rather than an OEM replacement. A quality aftermarket hydraulic replacement will cost less than $50, or there's the coilover for around $100, and a couple of other variations on the market.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
