steering spindles castings- 1 ton SRW to DRW ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 30, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    does anyone know for sure if 2wd 1 ton spindles differ between dually and single wheel ? hopefully just the rotors are what differ between the two
    any ideas ?
    thanks for anything
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    1-ton DRW and SRW spindles are the same. Calipers are the same. Only the rotors differ.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good to know, thanks for reply, i appreciate it /forums/images/graemlins/laugh.gif
    R
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    happen to be able to find out casting numbers off a 1 ton spindle ? maybe ?
    thanks for anything at all.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    My 1-ton suspension is still complete... I can't see any numbers - they must be behind the rotor.
    They should all be same...
    73-87 1-ton trucks
    88-91 1-ton crewcabs
    73-95 1-ton vans (heavy suspension)
    I got mine from an 89 2wd crewcab.
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    After I dug off the crud.... /forums/images/graemlins/grin.gif
    335669 LH
    335670 RH
    If you're out digging around in the boneyards, they will have 1.5" thick rotors as opposed to 1.25" on a 3/4-ton.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thanks for digging for the numbers, thats cool, lemme know if i can help you with anything
    so any size of rotors would fit on same spindles ?>
    thanks
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    Only 1-ton rotors fit the 1-ton spindles - they can be SRW or DRW rotors. 3/4-ton rotors will not fit on there (if that's what you're getting at)
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i think im getting at that,
    what happens if some 1 ton rotors are same number as 3/4 ton ones(thin 1 ton rotors) ?
    there are two thicknesses of 1 ton rotors i have seen
    hmm
    thanks
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    The thin (1.25") 1-ton rotors are the same as 3/4-ton stuff. They won't fit on 1-ton spindles, and vice-versa.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    crappy..
    thanks!
