Steering stabilizer -- run it or nay?
Discussion in 'The Garage' started by dremu, Apr 12, 2005.
  1. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    I just did the 8-lug swap up front to match my new 14BFF in back, and it was easier to drop in a matching-geared 10-bolt than to switch the outers and re-gear my Dana 44. (Thanks Iceman!)
    The new axle, though, doesn't have a steering stabilizer, and my D-44 was so greasy I was too lazy to pull the old one off yet.
    Doesn't seem to drive any worse; in fact, it drives better, seems like. I do not that my front springs are Ranchos and are STIFF (but hey, they were free -- thanks Desert Rat!)
    So, should I ... switch the old stabilizer onto this axle? Get a new one? Or run without?
    -- A
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if you're not having any probs, leave it off. Steering stabs basically just "cover up" various steering issues.. if you're not having any, you don't need it.
    j
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    just leave it off for now, however if u feel the need to put one on, then just buy a new one, they are dirt cheap at advance auto parts or sumthin
  4. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I had a good thread going with a poll until all the polls were deleted. But you can see by the posts that the overwhelming favorite was NO.
    Clicky --->Swaybar thread
    EDIT: Hell, never mind. I just realized I can't read. I was thinking "sway bar" not "steering stabilizer".
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    ill keep my duals until a hydro assist goes on.... :crazy:
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i like mine. drove without before, squirrly at freeway speeds and "spirited" driving. if yours feels uneasy then just buy a new one. ya they can cover up steering problems to an extent, but they also stabilize the steering when there's no problems, which is why they are there.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have run without a steering stabilizer for 3 years with no problems. I have run this setup with a few different setups including stock steering with 2.5" springs, raised steering arm with 2.5" springs, raised steering arm with 4" springs, and crossover steering with 4" springs. I have had no problems with any of them.
    Stabilizers just cover up steering problems like Jek mentioned. If your steering needs a stabilizer then you need to look at your steering and find out why. Spend the money from the stabilizer cost to fix the real problems.
    Harley
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'm running 40s and crossover with 56" springs and no steering stabilizer. Haven't had an issue as of yet but I only have like 35 road miles on it and about 10 of them have been over 45mph.
  9. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    havn't had one on my d.d. for almost a year now
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    when I went 3/4ton I just ran with out one for a month or so with out one because I had no problems and drove fine, But i just HAD to have one so I bought a dual set up and saw no differance just looks cool :D
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If it drives okay for you, don't worry about it. If it gets squirly, slap a new one on it.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The only thing I wonder about in running w/o one is if vibes you can't feel (there is a gear system btwn you and them) are working the pitman shaft bushes harder than if you had one.
