Steering Stabilizer Shock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Mar 18, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Can any shock type be used in place of the stock stabilizer shock? I'm running dual RS5000's up front and want to change out the old regular steering stabilizer shock sometime.
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yes. Just make sure it will work. Measure how long it will have to be compressed and extended, and thats how long it has to be.
    90K5
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i would go w/ dual steering stableizers. i put dual ones on mine. they kick arse!!! [ass] hehe
    they are rough country and we 90$ w/ the boots for free.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Actually...are you sure you need one? I had one with my old worn out tie rods, it was a Dick Cepek, and when I took the old ones off, it came off too and I haven't replaced it yet...haven't really needed it. I think they are sort of a band aid for worn steering components.
    90K5
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Shocks have more dampning on rebound than they do in bump. If you use a regular shock as a steering stablizer it will have more dampning turning one way than the other.
    '71 Blazer CST with alot of rust
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    TRIAGED IS CORRECT THE REGULAR SHOCK DAMPENS HARDER ONE WAY THAN THE OTHER, SO YOU SHOULD HAVE A REAL STEERING STABILIZER, NOT JUST A SHOCK. I DO NOT THINK THERE IS MUCH COST DIFF BETWEEN THE 2, THE STAB JUST WORKS BETTER. I CHANGED OUT MY FRONT SINGLE FACTORY STABILIZER WITH A SINGLE TRAILMASTER SSV STABILIZER, AFTER I HAD REPLACED ALL THE TIE RODS, AND IT MADE THE TRUCK MUCH MORE STABLE AT HIGHWAY SPEEDS. I THEN REPLACED THE SWAY BAR BUSHINGS WICH WERE ABOUT TO SPIT OUT THE OLD RUBBER PAD, WITH NEW POLY BUSHINGS, AND NOW THE TRUCK CORNERS LIKE A SPORTS CAR. THE FIRST THING I DID WAS TO REPLACE THE WORN OUT RED RYDER SHOCKS, WITH THE TTRAIL MASTER SSV'S, AND THAT ALSO MADE A BIG DIFF ON THE HIGHWAY.
    GOOD LUCK
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just "for your information", typing in all caps is used for yelling and is considered to be very rude when used consistently. It is also much harder to read.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Get a real steering stabilizer for it. Don't skimp on front end parts. Besides, a shock and a stabilizer are different designs. I don't mean to come off being rude er anything, I'm just getting tired of people skimping on so many important things just to be cheap or lower costs. I'm still kinda hacked at the arizona group that went and trashed some guys place.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
