Steering stabilizer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ron, Aug 29, 2001.
  1. Ron
    Ron Registered Member
    Jun 9, 2001
    55
    Washington
    I have a couple of extra Rancho 5000 s. If one is the right length can I use it as a steering stabilizer? Also are they good for preventing axle wrap of the rear end? Please let me know the pros and cons. Thanks Ron
  2. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I think Rancho 5000's are gas charged! I don't have much experience with them! If they are gas charged you can't use them. Steering Stabilizers are overrated anyway! Can anyone else help out?
    Bo
    If it breaks, it wasn't good enough!
  3. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    As long as you can get some mounts for the steering stabalizer that will work. It is the right length, go for it. Not sure about the axle wrap. Though. Good luck.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    RS5000's will not work as a steering stabilizer - it will be perpetually forcing you to turn left. Shocks provide a positive extension, and stabilizers are neutral dampers. That's the same reason why shocks are shipped with little bands on them to prevent extension and stabilizers aren't. If you can find the brackets, they can probably be made into kicker shocks for the rear - outside of that, they're spares.
    If the shoe fits, get another one just like it
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. 91SLE
    91SLE Registered Member
    May 24, 2001
    14
    Ohio
    You can use the shock if it is long enough to allow full steer. As for the axle wrap issue, you will reduce axle articulation if you install the shocks for axle wrap. My.02$
  6. Ron
    Jun 9, 2001
    55
    Washington
    Maybe there is something wrong with these 5000s because when they are colapsed or in any postion they will not move on there own. Let me know if that is the case. And maybe they would work as a stabilizer. Thanks For all the input. Ron
  7. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    Heh Ron,the Rs 5000 is not gas charged,that is why it will not move on its own.You could use it as a stabilizer but the valveing is a bit different.You do not have to worry about it pulling you to the side.
    chevrules...always has and always will
  8. Ron
    Jun 9, 2001
    55
    Washington
    Hey thanks for everything it sounds like I can use a couple of these after all. What a great sight. I guess I will fab up some mounts. Anyone have pictures of kicker shock spring mounts I can take a look at? Ron
  9. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I have a close-upp of the way my rancho steering stabilizer is mounted. Would'nt be to hard to fab upp a copy with some smal u-bolts and some plating.
    It's on my page below:
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  10. blackdog
    blackdog Registered Member
    Aug 8, 2001
    98
    New Jersey
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I just changed mine a couple of days ago, and it made a huge difference. Where do you get the idea they're overrated? Sure, it's not like they drive the car for you, but the difference is very noticeable.
    <font color=black> "Where did all these people come from, and how soon can they leave..."
    -OLD 97's</font color=black>
    <a target="_blank" href=http://www.k5.batcave.net>www.k5.batcave.net</a>
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would get a shock that is made to be a stabilizer. As metioned above a shock's valveing is totaly different than a stablizer's. They are not that expensive and you can even get a stabilzer with brakets.
    As for kicker shocks......waiste of time and money! If you have axel wrap problems kicker shocks will not solve the axel wrap it will only dampin it a bit and as thoes shocks wear your dampining effect will decreas and axel wrap will be right back were it was.
    .02c
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  12. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    Is a steering stabilizer worth the $ for a stock steering set-up? I can see some advantages if the vehicle is lifted but none for stock. I would assume it would drag the steering. Thanks,
  13. blackdog
    Aug 8, 2001
    98
    New Jersey
    Alex: The one I just installed is on a stock set up. I don't know if it came from the factory like that, but the stabilizer that was on there already looked like it was older than the truck! For about $30 for a Gabriel stabilizer, it's certainly worth it. It doesn't drag the steering, just gives it the right amount of firmness and greatly helps with bump-steer. Even if you had to but the brackets to add a stabilizer where one doesn't exist, it's not much more, and IMHO you get a lot of benefit for your money.
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Way back when 4 wheeling was young, and NAPCO's still walked the Earth, it was noticed that driving axles had gobs of bump steer, as compared to other vehicles. The aftermarket produced the mighty Heckethorn stabilizer to cure this problem. Around the early 60's, stabilizers became factory equipment on all 4 Wheel drives.
  15. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    My Jimmy was a wanderer, and I replaced the puctured original stabilizer (filled with water) with a new one, and it steers normally now.
    <font color=red>"Oil? That's not my oil...that was there before" </font color=red>[​IMG]
