Steering Stabilizer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PGL4VT, Sep 5, 2002.
  1. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    Can anyone tell me how in the world to get the bolt out of the steering stabilizer that goes through the tie rod? I can't budge it. I heated it with a torch and couldn't budge it. I cut the end of the bolt off and then drilled a hole in the middle of the bolt and I STILL can not budge that thing. Never have I had a bolt stuck this bad. Suggestions?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hehe!!! Too funny!! I went throught the exact same frustrating experience just a couple of months ago. I had to heat the sucker up REALLY good and then I got it out with a combination of an 18" pipe wrench and a BFH. It took me about an hour total to work the bolt out.
    The only problem I can see is that you've cut the bolt off. Is it flush with the tie rod end? You may have kinda screwed yourself by doing that.
  3. PGL4VT
    Feb 10, 2002
    71
    Roanoke, Virginia
    I cut off the end that has the nut on it (front of truck)so I don't see how I messed up. I'm gonna cut the other end off (stabilizer side) and put a socket on it and see if that will get it off.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All i did was had a buddy hold a 3 pound sledge on the back side of the tie rod(so it wouldn't bounce) and I hit the nut on the stabilizer and it popped right out.
  5. PGL4VT
    Feb 10, 2002
    71
    Roanoke, Virginia
    I tried beating it out with the nut on it with a hammer and it just bent the %&*# out of the bolt. That's why I had to cut the end off. It's not flush but close. I didn't think it was threaded in there but damn, I don't know. Is it threaded? It sure acts like it is.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    no its not threaded, its tapered so when you put the nut on its creates a press fit.
