Steering Stabilizer
Discussion in '1992-Present Chevy & GMC models' started by 92K1500Blazer, Dec 16, 2002.
  1. 92K1500Blazer
    92K1500Blazer Registered Member
    Dec 16, 2002
    7
    Anyone know if the 92 K1500 Blazer has a steering stabilizer shock? The Helms manual shows one in the diagram for the K model. Napaonline also lists it as a part for this truck, but I don't see it anywhere on the truck. Am I just blind, or have bad information?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I know my k3500 had it. There mounted to the steering arm that runs between the pitman arm and idler arm. One end mounted to that and other end to the engine crossmember. Runs right below the sway-bar.
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    my '94 doesn't have one either. but, i don't see any trouble not having one.
  4. 92K1500Blazer
    Dec 16, 2002
    7
    that's pretty much where the manual puts it, it's definitly not there. Front end is getting loose and just making sure I'm checking everything there is to check. Thanks for the replies!
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the steering is getting loose, then check out the thread "What wears out on IFS on 88-present trucks and..." Lots of good info there on getting it tightened up once again. /forums/images/graemlins/thumb.gif
