Steering Stabilizers
Discussion in 'The Garage' started by mudslinger99, May 3, 2005.
Which 1 is better ?
  1. One on top the other
    24 vote(s)
    42.9%
  2. Side by Side
    32 vote(s)
    57.1%
  1. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    What do you all think is the better way to go ? One on top the other ____
    ____
    Or side by side ____ ____ Post up with your experience thanks.
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    they do about the same either way... I think its more of a look thing then anything else
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If your steering system is in good shape you shouldn't need one steering stabilizer, let alone 2 of them.
    If you have to have a stabilizer then you need to search for the real problem in the steering system. Stabilizers just mask problems.
    Harley
  4. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    what H50 said. One steering stabilizer is fine, but if you really need two of them, something (potentially serious) is wrong with the steering system.
    j
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I took mine off and it is just fine
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I run a single stock stabilizer with 40's. No problem at all, and when I finally finish the hydro assist the stabilizer will be gone.
    Rene
  7. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Well at this point i have a dual over and under mount with only 1 stabilizer installed..And to tell the truth it looks to be pretty worn out and in bad shape but the truck still drives down the road perfectly straight..I have seen them both types i was just wondering would there be any benifits of 1 over another... thanks for the replys
  8. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    but they do look cool :D
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    A ram looks better...
  10. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    have you tried removing it and test driving it? might not even need one. lol!
    j
  11. mudslinger99
    Oct 8, 2004
    512
    East Coast
    No it was on there when i bought the truck so i haven't messed with it yet... I am not having any problems with the steering on the truck it drives great so far.. I was just curious if anybody on here preffered the 1 stabilizer on top of the other 1 or the side by side style.. I have seen both styles but didn't know if there was a difference in performance aspect between the 2.
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    well... if you're going to run two, orienting them one on top the other would make getting them mangled by rocks and stuff on the trail less likely. Thats the only advantage I can see to either option.
    j
  13. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I guess my all new Dana perfect circle and Moog steering parts suck right out of the box. I had wheel shimmy over bumps with the 36's till I put two stabilizers on.
  14. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Thats why I have my side by side with silver painted shocks :pimp:
  15. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if you run one on top of the other, the lower one hangs down more than a single stabilizer. i think side by side, even tho its across the whole tie rod basically, would provide a higher ground clearance.
    i know everyone says you dont need them if everything is kosher, but why have i seen so many stock vehicles with factory stabilzers then? are you suggesting they just have crappy steering geometry so they threw one on to mask the problems?
    also why do they always say in the catalogs " single for under 35" tire, dual for 35" and over". is that just a conspiracy to sell more units?
    just food for thought, so dont go flamin' me :D
  16. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yeah, thats one way of looking at it. No reason why you couldn't fab up a mounting bracket that had the lower one (in a over-under arrangement) about the same height as either on a side-by-side set up tho.
    stock rigs do have them though I can only speculate why. They do dampen sudden movements or vibes in the steering system, maybe they are there to "enhance" how steering "feels"?
    I wouldn't doubt it. It may just be old tech. I mean in the 70s or 80s dual shocks made sense cause shock tech sucked... enter monster trucks, racing etc and shocks have come a long way. Unless you do high speed desert whoops or something you don't need more than 1 shock per wheel anymore. Could be the same for steering stabs. In any case, I always like to recommend replacing the stock steering stabilizer with a hydro assist ram. :)
    j
  17. mudslinger99
    Oct 8, 2004
    512
    East Coast
    I understand to a degree to what a few have said about just masking a steering problem.... I have heard people say their having steering issues and think that a new stabilizer to replace the old 1 is the answer but after they install it they still have some issues... But on the same note like Johnny-K5 said they do come on some factory trucks so they must serve some type of valid purpose.... Also i bet most of us could count on 1 hand how many 4x4 trucks we have seen with any type of lift that does not have atleast 1 if not 2... Other then the clearence issues already mentioned can anybody think of anything else on 1 design versus the other ?
  18. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    how did this get back to the top?? :confused:
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't think it matters . Mine is in the stock spot , dented in from a rock . And it either still works or I don't need it as I have virtually no bumpsteer , and no shimmies and shakes .
  20. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Wait till your stabilizer shaft snaps off inside the tube. NO LEFT TURNY!! It takes alot of rights to make a left. :doah:
