Steering Stableizer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Capman2k, Oct 7, 2001.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    At high speeds especially it feels like I'm all over the place and it's pretty touchy... The guy I bought it from said something about needing a steering stableizer... How are these price-wise and what are the best ones to get??
    79 K5 <a target="_blank" href=http://www.geocities.com/capman2k/>Go Here</a>
    Wyoming doesn't exist, the map maker just needed to fill the space above Colorado[​IMG]
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    They run anywhere from $20 to $100. Just about every shock manufacturer has their own line - single hydraulic, dual hydraulic, coilover, etc. Depending on your needs. I switched to coilover, and will never go back to straight hydraulic - it provides a much better steering feel, but it also cost 90 bucks. Consider future plans, like lift/bigger tires before you buy one - if you ever plan on going past 31's, don't waste money on an OEM type, go with a burlier hydraulic or 2, or whatever. Pics of mine are here: pugsley.alloffroad.com
  3. Capman2k
    Jun 22, 2001
    5,070
    dg
    Okay, stupid question: Would that be $90 each or $90 for the set?
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Who makes that bad boy and where can you find em Jeff?
    Rene
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It's a 4Way Suspension by Trailmaster - $89.95 from 4WPW, Rocky Mountain Suspension carries them, and is a little cheaper - $79.95 from them. Trailmaster P/N#57201
    It's $90 total - you only need the one.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    YDM Jeff, thanks!
    Rene
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    No probbbblem!![​IMG]
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    How does that SICK stabalizer feel on the road?? i got a stock one one my d60 *insert snicker here* and i NEED a new set up...i can turn right with out meaning too! what axle is your stabelizer on?
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine's on a 10 Bolt - and let me tell you, this thing is heaven on the road. Wind gusts, grooves in the road from semis, absolutely nothing will throw it off course now. It was like swapping in an entirely new steering system from that standpoint - it even fights to hold the center, like a rack/pinion.
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    thanks! i will call RMS tommorw see if they have a dual for a D60
    -Zakk
  11. Capman2k
    Jun 22, 2001
    5,070
    dg
    Do any of the companies mentioned have websites for me to look at?
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Here ya go:
    www.rockymountainsusp.com
  13. Capman2k
    Jun 22, 2001
    5,070
    dg
    Thank you.. I'll be checking those out later... time to go back to school :(
  14. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Like others here... I have been digging Pug's stabilizer for a while now... and may switch to it in the future. I have a dual side to side stabilizer that I LOVE the Looks of... it also does a pretty good job IMO. Alot better then other dual stabilizers I have used in the past.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  15. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Any one know if the dual setup like pug's are the ones where they are beside each other or on top of each other?
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  16. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I believe it's the side by side - not sure though.
  17. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    There's no reason that wouldn't bolt onto a Rock Rod tie rod instead of the OE setup, right? I'm really liking that steering stabilizer.
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
  18. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It should go right on a RockRod, as long as you use the rod end with the mounting hole.
  19. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Pugsley - I just talked to RockStomper today (my crossover kit is shipping from them today). Scott there told me that you need the bracket with the "peg", not the hole... Just FYI...
    <font color=red>GOT MUD???</font color=red>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  20. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    For any D60 folks out there... I called TrailMaster today too! They told me that the 57201 will work fine with the D60! So quicker than quick, I snatched one of these bad boys up for the new cross over steering I will be installing next week.
    I called up Rocky Mountain Suspension, mentioned above (thanks Pugs!), and bought the 57201 for $86 with shipping!
    Check out more info on this cool and unique steering stabilizer at <a target="_blank" href=http://trailmastersuspension.com/products/stabilizers/coilover.html>http://trailmastersuspension.com/products/stabilizers/coilover.html</a>.
    Just had to share about my latest toy for the Blazer!
    My license plate reads:
    <font color=blue>8 YRSUV</font color=blue>
