steering stablizer???
Discussion in 'The Garage' started by smokkey1, Mar 20, 2004.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I was checking out the dual stablizer from rancho and it says for tires larger than 35" tires I'm running 36"swampers...so the question is who's running dual stablizers with larger than 35" tire? and is it a big difference than an single? just checking before I buy either one.
    thanks
    justin /forums/images/graemlins/burb.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i got duals on 35's, never run a single so cant say for sure. For ground clearance run 2 opposing ones, however I dont like the opposing lol. I have never seen an opposing that will give you full turning ability. The flanges on the pumpkin, where they come down to the axle tube, offsets the center bracket too far to teh driver side, keeping you from being able to turn all the way to the driver side. I like the over under style, even though you may beat the snot out of it if you do rocks. Mud it dont matter, just drag it on through like me.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i've got duals on 38's and can't imagine running a single with that setup. I just posted a link in the for sale for a ebay setup for just this...should go for cheap
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I ran a single with my old 76 on 40's. I almost no bumpsteer.
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks guys......stil not sure which to run......
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    well in life, more is usually better:
    two beers are better than one beer
    two ladies are better than one lady
    two k5's are better than one k5
    two tv's are better than one tv
    two steaks are better than one steak
    two speakers are better than one speaker
    two eyes are better than one eye
    two /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif are better than one /forums/images/graemlins/woot.gif
    /forums/images/graemlins/histerical.gif
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    two boobies are better than one boobie
    Fixed it /forums/images/graemlins/waytogo.gif
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well if you put it that way..... /forums/images/graemlins/smile.gif
    thanks
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I am designed my own just for that reason. As soon as I get it installed and tested, I may sell the brackets for it as a cheap kit (less than $50) So far, all the math works, I just gotta weld on the brackets and bolt in another stabilzer to see how it works! /forums/images/graemlins/waytogo.gif
  10. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Dumb question: why are duals better than a harder shock in the stock place? I thought the point of duals on regular shocks was so they wouldn't get hot and fade. Is the a problem with stabilizers?
  11. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Shane, let me know if that works out. I may be picking one of those kits up from you. /forums/images/graemlins/thumb.gif
  12. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Will do! The best part is, The bracket that gets welded to the pass. side of the axle will look like it came from the factory! /forums/images/graemlins/waytogo.gif
  13. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    bump.......
