Steering Stud Removal
Discussion in 'The Garage' started by Hossbaby50, Apr 22, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am wondering the best way to get steering arm studs out of a knuckle while it is still on the truck. I am not really worried about the old studs.
    How much torque should the new steering studs be put in with and how exactly do I go about torquing the studs into the knuckle? Should I use blue locktight? Thanks
    Harley
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    WD 40 and double nut them. Maybe even heat from a blow torch....
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I welded on the nuts cause I was replacing them. 90 ft lbs for the new ones, just install the studs by hand, then the arm, then the cone washers and nuts, then torque down. I used the blue lock-tite on mine /forums/images/graemlins/thumb.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sweet. that is what I was thinking but wanted to make sure. I just got my 4" studs and steering arm spacer from Sky so I need to install it so I can do crossover this weekend. /forums/images/graemlins/peace.gif
    Harley
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My studs in my '60 could have damn near came out with my fingers. I double nutted them and they came out immediately.
