Steering Thump"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rob 85K5, Feb 19, 2001.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Steering Thump\"
    When turning the wheel, in either direction, at low rpm's i get a thump sound from the front end. Is this the pump giving out? The fluid is at the correct level and it isn't any harder to turn the wheel when this happens. Any clues?
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Re: Steering Thump\"
    My Blazer's been doing the same thing off and on for over a year now. I had goodyear look at it when they rotated my tires and they said it was probably the steering box. Before I could try to fix it the thump went away. It comes back every once in a while. I would like to hear from someone whos knows more about this.
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    check your ball joints and all other front end parts. All though old trucks do like to kreek and thump just to make sure you're payin attention :)
    [​IMG] Keep your feet dry [​IMG]
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    That sounds like a cracked frame around the steeringbox. Common on these trucks with age and oversized tires. check out the ORD Steeringbraze reviu on the main page.
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  5. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I get a sort of thump too from my front end.. kinda like it lunges and pops when it does. Only happens when I'm going really slow, like parking in a lot or something. My friend says it's from my lock rite in the rear.. supposedly pushing the front end around. But, I dunno if that's true.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
  6. Rob 85K5
    1,487
    Pensacola, Florida
    I installed the ORD brace 2 weeks ago and the frame was not cracked, ball joints were replaced months ago and the truck might see 50 miles a month, so I know those aren't worn out. The thump also happens when turning the wheel while standing still. I'm still guessing the pump
    Rob 85K5
  7. Blazerblk
    Blazerblk Registered Member
    Jan 23, 2001
    15
    Chicopee, Ma
    Check the shackle bushings. Mine thumps also. When it is warmer I'm going to look at mine. I hope the problem will be an easy fix.
