steering too sensitive!!!
Discussion in 'The Garage' started by bigbadchev84, Feb 22, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    my steering is way too sensitive, i am all over the place on the road, is there anything i can do too help it?
  2. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    What type of steering? Stock, crossover, hydro assist, etc...? List the parts (lifted steering arm, block, etc). Try to better describe the problem - truck turns more than steering wheel effort, holding steering wheel straight the truck darts, etc.
    IMO, I doubt it's truely too sensitive. It's probably a loose part or bump steer causing it to wander.
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    it is stock steering, withe a 3inch block, and raised steering arm, the draglink is at a downward angle of about an inch, the balljoints and wheel bearings are new, it has a brand new single steering stabilizer on it and the tie-rods feel tight, it turns effortlessly, i can be driving down the road and even the slightest movement of the steering wheel and it will fly off to whatever side you are moving too, it just started doing this recently.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    To me it doesn't sound too sensitive, it sounds like you have excessive wander. Look at the toe. I like mine set 1/8" to 1/4" toe in.
  5. kevcarr59
    kevcarr59 Registered Member
    Nov 9, 2003
    35
    Austin, TX
    Steering...
    You may also want to check your steering gear preload. If your steering box is original and has a lot of wear that could be it. You have to be carefull though, don't tighten too much or you'll mess up the pump.
  6. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    Sounds like you have a nice case of toe out, or your castor is incorrect.
  7. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    the raised arm with the block is most likly going to cause the bolts to loosen or brake from the extra pressure there. i would get a drop pitman arm and only the raised arm if that will fit your combo. only if the toe problem is solved . this is just a sugestion.
  8. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    go to your rig and with a friend and a measuring tape, measure the middle of the front of the rim, from rim to rim, the measure the middle of the back of the rim from the inside.
    should only be about a 1/4 inch difference, with a 1/4 or 1/8 less in the front then the back.
