Steering veers left after hydroboost install...
Discussion in 'The Garage' started by stevos67k20, Dec 1, 2006.
  1. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    ever since i installed my hydroboost i have noticed that it turns easier to the left and when i drive at speed it wants to pull slightly to the left. it never did that before hydroboost install. also when i tried to bleed the system; the wheels would turn in jerks instead of a smooth turn from left to right. what do i need to do?
    thanks
    steven k
    :truck:
  2. stevos67k20
    Sep 29, 2005
    140
    Somis
    anyone know?
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Double check the hose routing. After that, restrictions or kinks in the return system could cause the problem. Are you running a "T" or the dual return? I ran the "T" method for a while, but the system works much better with the correct reservoir (two return nipples).
  4. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    The wheel jerking could mean too much pressure from the pump ... do the brakes pulsate as well, like does the pedal pulsate under your foot when you press it down? That would indicate too much pressure from the pump.
    Also, bleeding a hydroboost system is a PITA ... turn the wheel *and* press the brake pedal (just a little) with the front end up.
    I find a piece of radiator hose on the reservoir allows you to keep fluid in it, as it will want to burp fluid out while bleeding.
    -- A
