steering wanders
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Aug 21, 2004.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    I just acquired a 76 Blazer, with 8" lift, and 35" tires. The steering seems loose, as it wanders or 'walks' from side to side while driving. At higher speeds it can be a challenge to control. There is no visible crack in the frame. Also, the steering wheel, while most of the time is horizontal, rotates 90* on its own to vertical, then back again. Lastly, the steering turns very easy. Yet it seems to be geared maybe 2:1; more revolutions on the steering wheel than felt by the tires. Any ideas?
    This is my first 4x4. My 1990 C1500 steering is solid. I expected something similar on the Blazer.
  2. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    Possibly a bad steering box.
  3. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    That's an EZ one to figure out...jack up the front end, tires off the ground...and check for serious movement when you grab each tire. Check for up and down and sideways "play." If all is secure/tight then the steering box is more than likely the fault.
    Take it to a front end shop for a check up and go from that point on what to do.
  4. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Have you had someone steer it while watching steering box and frame. I couldn't notice the cracks until the frame would flex when moved. Should get brace anyways if it doesn't have it, will be matter of time before cracks from.
  5. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    I second what Bruiser said, have someone crank the wheel back and forth and watch the box...
    I have a lot of the same symptoms (wandering, steering wheel never seems to be in the same place, etc.) and I was amazed at how much the steering box was moving. /forums/images/graemlins/eek.gif This is with no visible cracks in the frame.
    Sometimes it will make a nice cracking sound as the steering box shifts.
    Yeah, definitely time to call ORD. /forums/images/graemlins/weld.gif
  6. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    sounds like maybe a bad Tie rod or drag link end.
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Could be alot of things. You need to investigate furthur. Steering shaft slip joint is a very commonly overlooked one. Bad steering box is unlikly, and should be the last thing to suspect...
    Check here
  8. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Mine did the same thing, the steering rod, that connects he steering box to the linkage goes bad. Needss to replace it, he balls are too loose. Tighten up the adjustment rod there, and that should stop the steering wheel from goign 90 degrees.
    Edduie
  9. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    I have spent two years trying to correct the same problem on my ’86 Blazer
    New Ball Joints,
    New drag link,
    New tie rod ends,
    Frame repaired at the steering box (Most times you will not see the cracks until the box has been removed),
    I have even installed the brace from Off-road Design. (The brace made a huge difference.)
    That is until I put more air in the rear tires. It seems that I had underestimated the amount of air pressure needed.
    What a difference!!! Even with no sway bars I now go into corners without a worry.
    Although I have tried all of these repairs, the frame is still getting a replacement. Found another frame that still has original paint.
    This replacement will be reinforced at all the necessary places and I will be installing a ¾ ton driveline. The tires will be kept at or below 33”.
    Some times I look for a hard remedy to an easy problem.
