steering weel centering?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by carolina custom, Feb 15, 2002.
  1. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Just installed my Hill 4wd extended fromt shackles today. All I can say is they look huge compaired to the stock ones. The problem is now is my steering weel is 3/16 a turn off center. Is this dew to increase in drag link angle from a 1.5" increase in ride hight, or the change in caster degree, or could I have messed up?
    84k20,18:1- 6.5td,400/208,4.10,4",35"s
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    It's dew to the drag link angle. Just like when you add a suspension lift your steering wheel gets off. Just loosen it and adjust it. No big deal.
    BE <font color=blue>AMERICAN</font color=blue> BUY <font color=blue>AMERICAN</font color=blue>!!!!
    So Cal Big Dawgs are coming to a wheeling spot near you!!
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    wait a minuite i can just loosten it up and straighten it out?! where at, in the wheel behind the horn button?
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  4. Esteban86K5
    3,712
    Bakersfield, CA
    On your drag link you have an adjustable sleeve with 2 bolts that hold the clamps on. loosen those 2 bolts and turn that sleeve, you will see the steering wheel move.
  5. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    It's due to the change in drag link angle, I believe. Loosen the two bolts on it and use a pipe wrench to turn the adjuster sleeve thingy (I don't remember the real word for it), to make the draglink a little longer, I forgot which way you should turn it to make it longer, then tighten the two little bolts back up and you're good to go. I know I'm a little vague, but I forgot all the technical terms for everything, so just look at it and you should be able to figure it out if you haven't done it before.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  6. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Thanks, thats what I suspected. Was shocked by how much it is off.
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You should see mine, went wheelin and came back and it was a quarter turn off....Nothing bent, broken, or loose. SSSSTTTTTRRRRRRRRAAAANNNNGGGEEEE!!!
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    If you install an ORD steering brace, your steering wheel will stay centered even after all day of wheeling.
    You're right, it is strange and my truck used to do that too. No more.
    -- Mike
    See <font color=orange> Project Old Orange! </font color=orange><a target="_blank" href=http://users3.ev1.net/~mattell/>CLICK</a>
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    my friend put a 4.5 lift on his heep and his steering wheel was a bit more than 1/4 turn off... it looked funny when he drove with it like that.
    hrm i should look into that brace
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 6"susp, 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is usually attributed to the adjuster sleeve bending
    formerly 77chev
    still a jerk though
