steering wheel and horns
Discussion in 'The Garage' started by RubberFloorMat, Jan 24, 2006.
  1. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    394
    41
    Oklahoma
    my wife got me a steering wheel out of a 94 Truck for my blazer, the horn button is different obviously, but it went right on, no issues.
    the wiring thingie is not even plugged in or anything, and it keeps honking for no reason, is something jacked in the collumn now??
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Was there a wire on the old steering wheel? If there was, every time that wire touches ground, the horn will honk.
  3. RubberFloorMat
    Dec 12, 2004
    394
    41
    Oklahoma
    ya there was, but not anymore.
  4. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    Did You take the little spring and plunger looking assembly out from the column. Because I forgot to do that when I put my grant wheel in and the same thing happened.
  5. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    A lot of horns have a ground activated wire. I am not sure about your model.
    If the wire "isn't there anymore," how was it removed? If you pulled it out or just cut it off, it is possible that the end of the wire is still hitting the column somewhere and grounding out.
  6. RubberFloorMat
    Dec 12, 2004
    394
    41
    Oklahoma
    i pulled the little plunger and spring out, nothing is connected at all that i can tell, but you can hear it clicking under tha dash.
    91 K5 Scottsdale, base model, no cruise, thin little stock wheel.
    im at a loss, gonna investigate further tomorrow.
