Steering wheel asembly Is Loose as Hell
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The Big Unit, Nov 4, 2002.
  1. The Big Unit
    The Big Unit Newbie
    Nov 4, 2002
    Great Lakes
    Hey All...Anybody have any ideas why my whole steering column assembly would be so frickin loose..checked the bolts on the bottom ..all is tight.. steering box has little play...but the whole column ,gearshifter and everything is not tight at all...about ready to fall off...but still drives...
    Any ideas?? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    is it a tilt wheel? if it is there are 3or 4 bolts inside the colum that need to be tightened you have to take the colum apart to get to them
  3. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    What he said, remowe steering wheel and blinker assembly and you will find torxhead bolts. I had that same problem last week.
  4. chevelless502
    chevelless502 Registered Member
    Jun 5, 2002
    45
    Colchester IL
    Yup, its an easy fix to tighten them up once you get the steering wheel off. Its very common on 4wd trucks cause alot of people use it to get in and out with.
    Andy
  5. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If you want to do it yourself do a search on here. Someone here has a very detailed description on the whole process. Sorry, I can't remember who. I found it, it was by Bigburb. Search for loose tilt steering
  6. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
