Steering wheel internals
Discussion in 'The Garage' started by Justin Fleming, Aug 25, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    Does anyone have a diagram of the steering wheel internals for a k5 blazer?
    I was having horn problems and as began to dig into it appears someone has had the wheel apart...............
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    http://columnsgalore.com/images/COVER_ART_2.jpg[\img]
    EDIT: picture is here:
    [url]http://columnsgalore.com/Parts_intro.htm[/url]
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Well that give me an idea, But I still need something with more detail to see how the spring,pin and little plastic lock thing is supposed to go........
  4. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    I have a manual.. I could scan what you need if you like?
  5. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    That would be awsome
    I would love it if you could please scan that stuff in and send it to me at jfleming01@caharter.net.
    I just purchased this truck and someone has been in the wheel and messed things up......I found a broken plastic piece that I think holds the spring and pin in place.......
    again
    Justin
  6. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    What year is your Blazer? Tilt steering column, or no?
  7. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
  8. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
  9. dyeager535
    26,982
    191
    Part 17, page 5b sounds like what you think is broken.
    It's the turn signal cancelling cam, but it also has the "socket" that the horn spring assembly locks into. The plastic "socket" protrudes through the lock plate (black metal piece with all the cutouts along it's edge) and the spring assembly for the horn is pressed into that, and a button on the spring assembly latches into a cut in the side of the socket. Same idea as the turn signal bulbs with the nubs on the side of the bulb, and corresponding slots in the socket for them.
    Hope that helps in some way.
  10. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    what you described is what I need
    where is the material that your referring to??
    thanks
    Justin
  11. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    3 posts up, by 6.2LTrailblazer84, he scanned in the manual for you
  12. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    so the farther I go the worse it gets
    Does anyone know how the turn signal arm connects to the turnsignal switch??
    there is this metal tab that has a ball on the end of it that appears to go into a slot in the turnsignal arm, and then some how it has to hook up or actuate the turnsignal switch..............any ideas?? The arm just seems to fall and not have any spring to it or stay in the center position
    Also when you assemble the hurn button/contact, what is the order? spring, then button, then black retainer I thing??
    thanks
    Justin
  13. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    the turn signal ball fits into a groove on the switch, and its held firm by 1 or 2 screws. There are two small springs that fit into the switch that hang down below the switch. The turn signal cancel cam hits these, and thats what turns the signal off.
    Spring goes in first. Then the retainer and snap ring. Then connect the horn wire, and snap the pad back into place.
  14. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Randy
    I think I just figured out how the turn simal thing works.....It appears that there is a screw missing that is supposed to hold the metal arm attach to the top of the turn signal switch.....
    So you dont think I am some dummy.......I just purcahsed this truck from a guy that had all this stuff aready taken apart.....thats the reasons for all the silly questions....
    If you have an email address I would like to send you some pics.....If interrested send me an email to jfleming01@charternet. I think this horn switch is a little different then what you are discribing......
    thanks again
    Jusitn
  15. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    Justin, sorry if the information you needed wasn't there. That was the entire steering wheel and column section in my manual.
  16. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Finally Got it
    Well I have finally got all working well......After two trips to the dealership, a 9 dollar part, 1 screw missing, 8 hours of working, two new pullers and I have 1 horn that works and blinkers that work correctly now.
    BIG thanks to all for the help
    Justin
  17. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    Maybe you should do a write-up. Keep us other folks from havin to go through that. :D
  18. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    I would have
    But the pictures my camera took where horible.......I deffinetly feel that I could offer anyone help on this issue now......
    Next Issues will be the rear window switch that allows the window to go up and down by the key......I have it all apart but the contacts are burnt.....They wany $60 to purchase a new one.....But that comes with everything and I just need the contacts.....
    Justin
