Steering wheel play?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tach, Jun 28, 2001.
  1. tach
    tach Registered Member
    Jun 23, 2001
    8
    Would rebuilding the steering box help get rid of excess play in steering? If not what would?
  2. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Yes it would. Play is years of wear and tear. You'll almost always have a little play because of the ratio's. Check all your steering componets for play. With a new box you should get rid of alot of it.
    Other than a new box if everything is tight, can't think of anything to get ride of play.
    Anyone else have some info?
    Rasberry 71' K/5 Blazer
    <A target="_blank" HREF=http://www.geocities.com/71blazer>http://www.geocities.com/71blazer</A><P ID="edit"><FONT SIZE=-1>Edited by Rasberry on 07/03/01 05:25 PM (server time).</FONT></P>
  3. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Tach,
    Before you tear anything apart do this. I had lots of play on my '72 (76,000mi). A spring/alignment shop showed me that the rivets loosened up on the front left spring bracket, where it mounts to the chassis. With the engine off have someone work the steering wheel back and forth while you look at that bracket. You'll see the bracket move if the rivets are bad. Also you'll probably see oblong wear marks on the bracket and chassis around the rivets. E-mail me if you find this to be the problem and I can send you details on how to proceed w/ the repair. Good luck! madbishop@msn.com
    You can't beat going Topless!
  4. Ressurection
    May 9, 2000
    360
    by the way, after that repair my steering wheel play was gone completely.
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check drag link my 87 had some play drag link ends fixed it.
  6. MikeS
    MikeS Registered Member
    Feb 15, 2001
    20
    Charlottesville, VA
    Also check out the rag joint which couples the steering box to the column. I found mine just about torn in half. Amazing the difference replacing that made!
    Mike
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    You can adjust some of the slop buy turning in the allen head screw on top of your gear box.
    Caution!! Don't over tighten that adjuster you will overheat your steering box.
    You want to rock your steering wheel back and forth with out turning the grear box output shaft. This is the slop that screw will minimize. do NOT remove all the slop just tighten it to the point you have just a little bit of slop left and leave it there. Make small turns to that screw and check slop inbetween each turn.
    Hope this helps
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  8. 70Dave
    70Dave Registered Member
    Jun 1, 2001
    12
    Cincinnati,Ohio
    Also check your front crossmember. Mine had the rivet heads sheared off, allowing the frame to twist slightly. Front bumper also acts to hold frame together I am told. I have reduced my slop by about 75%. Still working on the other 25%.
  9. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    I had almost 1/2 turn of play in my wheel when I first got the truck. Found a few things that might be worth checking. The bushing between the colum and the steering box. Mine was worn out and not holding the two tight. Drag link ends. Mine were worn and a new set really helped. But my big problem was the spring pack centering bolt was sheered of on the drivers side allowing the axle to slide back and forth instead of turning. Hope this helps!
  10. greatwhite
    greatwhite Registered Member
    Jun 2, 2001
    14
    san diego, california
    good question, i needed this help also
