steering wheel play
Discussion in 'The Garage' started by hammermachine, Sep 19, 2006.
  1. hammermachine
    hammermachine 1/2 ton status
    Aug 23, 2005
    2,450
    6
    Still in New Jersey!
    Does anybody know how to tighten up the steering on at K5. The wheel feels real loose.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Loose as in WHERE? The tilt loose, the wheel loose, the steering loose? Need a little bit more of a description.
  3. hammermachine
    Aug 23, 2005
    2,450
    6
    It's loose up and down ( not a big deal) but as you drive it feels losse/ worn. It feels like you could over correct very easy. I don't know how to explain it any better, sorry.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like your tie rod ends or maybe your drag link ends need replacing.
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    get under there and shake everything to see if anythings loose. i had a problem like that where i would sway on the highway, over time i replaced the box, pump, rag joint, stabilizers, hoses, fluids and it has only about 30 mins. (in time degrees whatever) at the top. when i replaced the rag joint supprisingly changed it alot.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Lay under the front of the truck and have someone slowly rock the steering wheel 1/2 turn left to 1/2 turn right. Look for where the play is. Most common spots are in the drag link ends and where the pitman arm is bolted to the sector shaft.
  7. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Also don't forget to check the rag joint.
    After new tie rod ends, drag link ends, rag joint and steering box, my steering was still loose. I ended up having to tighten up the steering box. It was a reman unit from O'Reilly's. It's still not as tight as I would like it, but hell, it was only $125.
  8. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    thats why i installed this
  9. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I wonder how noticeable the difference is between a (new) rag joint and U joint.
  10. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Do you have a tilt steering column?:rolleyes:
  11. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I went from a rag joint that was in reasonably good condition (not much slop) rag joint shaft to a dual u-joint shaft. I also did a steering brace and a slight box preload adjustment (you have to be really careful not to get it too tight, or it could lock up on you - in the middle of an off-ramp, perhaps, crash and burn). I went from over an inch of play to very little, mostly sidewall flex. Like a previous poster wrote, get a helper to turn the steering wheel back and forth, and get underneath and look for the slop.
  12. hammermachine
    Aug 23, 2005
    2,450
    6
    how hard was it to install the steering shaft?
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  14. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I put a flaming river shaft and u-joint setup in mine and it made a difference. everything else was new from when I went crossover.
  15. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    mine came from a xj. cheeps have some good parts like that steering shaft!!LOL it bolted right up.
