Steering Wheel Revolutions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Nov 12, 2000.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    For all you full size steering wheel blazer drivers....... From stop to stop, how many revolutions does your wheel make? Mine goes 3 and 1/4 turns, I can make incredible U turns but I can barely get around a right hand corner. I noticed the rear tie rod for the steering arm is really long and butted up against the other tie rod inside the sleeve so it cant be adjusted. I think the easy solution is to replace the long tie rod with a shorter one but wanted some input from some people first.
    creepin' and crawlin'
    Jim
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    My wheel goes 3 1/2 turns lock to lock. 1 3/4 turns each way. It turns very sharp left or right, maybe a little sharper going left. Does that help?
    Rene
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yessir it does, I think its just a matter of changing the other tie rod so I can adjust the wheel correctly. Thanks a bunch.
    Jim
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The long one should be in the front, and the short one towards the back. I just got done changin the ends and I noticed left would hit the mechanical stop at the knuckle, but right wouldn't. I adjusted the length to get lock to lock, then my steering wheel wasn't centered- damnit[​IMG]. When I use the adjuster sleeve to center the wheel, it doesn't go lock to lock- 2xdamnit[​IMG][​IMG]. I wound up "customizing" the steering wheel and turn signal mech to get it straight.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
