Steering wheel upside down after lift!
Discussion in 'The Garage' started by Eagle Driver, Nov 7, 2005.
  1. Eagle Driver
    Eagle Driver Registered Member
    Oct 19, 2005
    25
    Florida
    Got a Blazer, got a lift kit, got an upside down steering wheel :doah:
    I am new to the world of K5's, and I just put on a 4" Tuff Country lift on my 87. Everything seemed to go well (still need to extend the brake lines), except when I jumped in the truck to fire her up, I noticed the steering wheel was upside down. Must've happened when I was messing with the steering arm and "that other piece it connects to".
    How do I fix it?!? I don't want to take off big pieces, my arms are tired from loosening rust frozen bolts. Is there any easy way to disconnect the wheel and rotate it in the cab?
    Thanks ahead of time!!! This forum was instrumental in me disconnecting the steering arm (3 pound hammer, PB blaster, and a six pack).
    Also, wtf is bump steer, and how do I know if I have it? Ok, enough ?'s for now...
    THANKS!!!!!
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    You changed your steering geometry so you will have to adjust it back to factory. Your drag link should have adjusters. Adjust it till your wheel is striaght. Bump steer is bump...oh ****(pulls to left or right).
  3. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    just got through with my 4'' lift saturday Iwas wandering the same thing with the upside down wheel
  4. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    1. losen the nuts on your drag link adjusting sleeve
    2. Turn adjusting sleve till wheel is straight
    3. go for a drive, see where wheel sits, if not straight pull over and turn sleeve some more.
    4. repeat step 3 until wheel is where you want it.
    5. tighten nuts on adjusting sleeve.
    6. pat yourself on your back. :D
  5. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    do a search. it's been covered before. after i read the search results mine 6 inch lift came out fine.
  6. Eagle Driver
    Oct 19, 2005
    25
    Florida
    thanks sheoldeblaze...I will give it a shot tomorrow...appreciate the help :D
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Just leave it like that, because soon you will be putting in a D60 with a zerorate and moving the axle forward again anyway...lol
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is why you go crossover then you dont have to worry about adjusting the draglink. Anytime you mess with the suspension you should align it. Wether you take it to a shop or if you do it with a tape measure you should always align it. Your tires will thank you.
    Ira
  9. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    Check out J.C. Whitney p/n AJT815939. I've gotten some good advice from this forum and would like to return the favor.
  10. GaBnn3
    Jan 2, 2005
    90
    Holyoke, Ma.
    This may be a duplicate reply. I already replied to the last post. Oh well. Go to www.jcwtruck.com. Check out p/n AJT815939.
