Steering wheel won't return to center
Discussion in 'The Garage' started by 1987Chevy, Nov 2, 2005.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    I was wondering if any one else had this problem I'm running 4" TC front springs with a sky Jacker drop pitman for steering correction with 33" Xterrains the problem is when I make a turn the wheel will self correct all the way up to about a 1/4 turn away from center the last quarter turn I have to turn it back my self or it will just stay there. There is nothing binding in the steering system so I was figuring it was probably caster angle. Now I was wondering what people would recomend to fix this like running shims (if shims are recomended what degree and sorry about sounding so dumb but positive and negitive caster always confuses me so which direction should the shims face) or having it aligned or any other suggestions because I thought I could live with it but this truck is a some what daily driver (when i could afford gas :D ) and this non centering wheel is starting to become a real PITA. Thanks in advance for anyones help
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i would have the alignment checked first. then go from there. try to find a shop where one of the techs drives a lifted truck. they do better alignments and are more understanding then the old-schoolers that will tell you that it can never be right once it has been modified.
    ryan
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Toe-in is what causes your wheels to self-center. Have you had an alignment lately?
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Toe in? Wrong...its caster that centers the wheels, which can be affected by lift kits.
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Sorry, my bad. So to make up for it...
    From the Chevy service manual...
    Solutions to "poor returnabiliity":
    Steering column adjustment
    Steering linkage needs lubrication
    Idler arm bushing worn
    Steering gear adjustment
    Power steering gear valve spool binding
    Obstruction within power steering gear
    Improper caster setting (negative)
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    It's all good :D
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    PUSH THE AUTOPILOT BUTTON ON :rolleyes:
  8. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    check ur center pins. i had this problem. where i would turn and my wheel wouldnt be the same when i was goin straight. i had someone turn the wheel back and forth and i check everyting and my axle moved back and forth. ended up bein broken center pins. have a buddy sit in ur truck and turn the wheel back and forth while you go over teh whole system.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    auto pilot engaged
    heh
