Steering wheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nikk, Feb 27, 2003.
  1. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    Hey,
    I have an older sport steering wheel that I'm not going to be using on my Chevelle project, I would like to install it on my truck if possible. It's a wood wheel, your average 3 spoke with holes running down on each spoke. What would I need to install this(an adaptor?). Where would I get something like this and is there a specific name for it?
    Thanks again. /forums/images/graemlins/grin.gif Nick
  2. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    if the wheel is anything like a Grant wheel, just by their adapter for a chev truck. Or if you know the brand try and see if they have an adapter. If all else fails and your handy, you try and make your own adapter or modify one with the same type of splines inside the hub.
  3. BRN78BLAZER
    Feb 5, 2003
    133
    just had another thought, If you can't get the adapter, you could cut apart an old gm truck wheel down to just the hub, then drill it to fit your wheel on, fix on a horn cap(good luck making the horn actually work) and you'll be good to go.
  4. Nikk
    Dec 16, 2002
    34
    Lacrosse, WI
    Thanks any other thoughts from anyone
