Steering Wheels: What do You Have ?
Discussion in 'The Garage' started by mudslinger99, May 19, 2006.
  1. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    It seems in the 73-87 pickups that the steering wheel is way to big and requires you to put in a smaller one.. I have one I need to change and trying to figure out which one to go with..
    Post up what make and model you have and your opinion of it.. Pics would be nice too :D
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Here is what i went with...
    A bit over 15" diameter, stock is over 16" IIRC. Mostly this one is just a ton more comfortable.
    this one was from a '92 K1500
    Rene
  3. mudslinger99
    Oct 8, 2004
    512
    East Coast
    I actually thought about going with one of those because I like the one in my Z-71.. I haven't measured it yet but it seems like it still might be to big.. I thought the stock 73-87 wheels were just about 17 inches and those were about 16 inches :confused:
    In my 84 the stock wheel almost hits my legs and without a tilt column the only other option is to go with about a 2 inch smaller wheel.
    What was involved in putting that wheel in ?
  4. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    i have a grant wheel in mine, its about 13-14 inches, it was in an old truck i bought and i just kept it when i got rid of the old truck. it looks kinda small on the truck but feels right while driving it.
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I don't have my old wheel to measure, but did measure this one at a bit over 15". Installation is pretty easy...unbolt old wheel, pull off, install new wheel tighten nut. Mine was missing the horn junk inside so i never got the horn hooked up...but I've been told it all works if you get one that's complete.
    Rene
  6. mudslinger99
    Oct 8, 2004
    512
    East Coast
    The horns are different so I thought you might have had to modify or change something to make it work.. But if you didn't hook it up I guess that wasn't an issue for you :doah:
    I will have to measure mine because I need to go about 2 inches smaller than whatever is in there now in order to clear my legs and make it more comfortable to get in and out..
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Yeah the stock is perfect for me. I have no tilt steering, it just seems to be in the right place.
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I like the 89-93 style like rusty. That's what I put in my 84.
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    this one's like 45 bux, and it's pictured full size. 3/4" diameter! just get some JB weld and go!
    :D
  10. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    hell, mine is too far away from my legs. i am going to raise my seat about 2 or 3 inches just so the wheel feels correct.
  11. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    193
    Santa Maria, CA
    What is different? It looks like you have the horn pad. Is it because you don't have the wire running from the column to the pad? If so, get a cheap in-line bus fuse holder, take it apart, and take one of the wires with the copper end. Then take out the copper plunger out the column by twisting the black plastic holder. There should be the plunger, a spring, and the black holder. Remove the plunger, and insert the wire though the spring and holder. Clip on a female spade on the end of the wire. Reinstall the holder by twisting it on. Hook the wire on the spade on the horn pad. Reinstall the horn pad.
    The horn system works by grounding out the horn circuit. So when you press the horn button, the hot wire grounds out on the steering shaft and complete the circuit and the horn works.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Every GM truck I buy I replace the stock wheel for a Grant GT wheel. I just hate the stock wheel as they are just too big. Like driving a semi truck. The Grant GT wheels are the perfect size, IMO.
  13. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    Grant GT all the way. Thick grip, easy install. Smaller diameter masks play in steering a little.
  14. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Come over to my house, I have a suburban witha tilt column and that kind of steering wheel. Not only will it tilt but it will be smaller. Or I have 2 of the larger wheels on tilt columns too. I don't know if I like the big skinny ones or the small fat ones though.... Current girl is tall and skinny though... :haha: Guess I like them both for different reasons. Definitly liked my 85 K5's fixed/stationary and ratty seats (much more cusiony and comfortable) of my 90 Jimmy's reclining seats.
  15. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    I only use the stock steering wheels, dont like the smaller steering wheels, they feel like gokart steering wheels. I do like the 89-93 steering wheels. I have one in my 89 burb and if I found a good deal on one I'd put it in my 85.
  16. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
  17. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I have the same steering wheel in my 75 burb as Rene has in his rig but a Bowtie version. I got it out of a 91 chevy van. Horn guts were there and everything hooked up without any modifying....works great and I love it :thumb:
  18. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i love my big ass steering wheel, gives me a little bit more leverage when steering
  19. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Flat Black Grant GT, I love it
  20. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    a lot of them fit..
    I put a Cavalier steering wheel on my 74 K20,after installing "custom" bucket seats, the OEM wheel was cutting a groove in my legs..it fit perfectly and the horn worked fine too..
    I found while junkyard shopping nearly all GM steering wheels share the same splines and colum diameter..many Fords fit too!..lots to choose from..:crazy:
