steering?????
Discussion in 'The Garage' started by jekquistk5, Aug 4, 2004.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Ok,
    Just took the k5 on her first road voyage since the lift and tires, ive got alot of bump steer, and i have alot of play in the steering wheel. From 10-2 its dead, i just put a new PS pump in less then 1k ago. Any suggestions /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  2. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Get a new Steering Gear box.
  3. 55chilly's
    55chilly's Newbie
    Feb 12, 2004
    what did you do to correct the steering for the lift, is it tight? that or its could be your box. have someone rock the wheel and forth while the engine is off and look for the play-its either in the linkage or the box, the pump has nothing to do with it
  4. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I used the steering arm correction kit from tuff country. So it could be the box?? i never noticed any play with smaller tires. And should i jack the front end up to check for the play in the linkage?
