Steering
Discussion in 'The Garage' started by ttihsllub, Aug 22, 2004.
  1. ttihsllub
    ttihsllub Newbie
    Aug 21, 2004
    castle rock, colorado
    When i purchased my 72 K5 there was a lot of play in the steering. Does anyone have any ideas on how to help my situation?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    welcome to CK5, take a few minutes to fill out your profile so we know what your working with. /forums/images/graemlins/waytogo.gif
    there can be quite a few thing assisioted with loos steering, one check the tierod ends and the draglink ends. if those are good, then check the rag joint on the steering shaft before the steering box. also check the "bell" joint on the column near the firewall. if all those are good, then the steering box is probably loose. there is a way to tighten it up but not sure exactly on how to do it.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Just have someone move the steering wheel back and forth without actally breaking the tires loose, and see where the movement is.
    I've seen steering boxes that were loosening up on the frame, or the frame being cracked. The wormgear inside the steering box could also have some play in it. They mentioned that here.
    And also, what he said.
