steering
Discussion in 'The Garage' started by fatboy, Mar 29, 2005.
  1. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    I bought a 83 Jimmy with a six inch lift but the PO never adjusted the steering geometry. So as i am looking around i see that you can get a raised pitman arm, drop drag link, or a drop steering arm. So of these choices is there a benifit to one or the other besides price? It has a 6 inch lift, 35" at's right now. Oh i am not doing crossover steering on it yet :confused: :cool1:
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    For a 6" lift I would use a raised steering arm.
  3. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    dont buy a drop link. you will throw it out in less than 2 weeks. thay suck. drop arm for box or raised arm for axle. any more lift then crossover setup. but thats a whole new thread there.
  4. fatboy
    Jul 1, 2003
    290
    Tennesse
    thankyou :D
  5. fatboy
    Jul 1, 2003
    290
    Tennesse
    another question
    what is the best way to get the cones out of the pitman arm? The PO tried a chisel :crazy:
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    My $.02............oil soaking..................then heat, lots of it...............then the BFH!
  7. divorced
    Jul 20, 2004
    5,115
    I live in the rust belt and have never used heat or penetrating oil. If you use heat you must like to replace ball joints, because it will burn the rubber boots off. Jack up the truck, take off the tire, set the axle on a jackstand neer the knuckle. Just a 32 ounce ball peen hammer, just don't swing it like a sissy. You hit down on the steering arm real hard, on the side opposite of the cone washers.
  8. sweetk30
    Nov 1, 2004
    25,546
    542
    like he said but i use a 4lb hammer and hit the end of it . the shock pops them out. but leave the nuts on in case thay try to pop out and go flying.
  9. fatboy
    Jul 1, 2003
    290
    Tennesse
    will do tomarrow thanks
  10. fatboy
    Jul 1, 2003
    290
    Tennesse
    well the pitman arm is off :) but I broke the front stud off in the steering knuckle :mad: is that screewed in or pressed in? Should I try to drill it and get it out or just start looking for another knuckle :confused:
    heat, blaster, and 10 lb sledge I have got to stop going to the gym :blush:
  11. divorced
    Jul 20, 2004
    5,115
    I have never actually removed any of the studs, but I'm fairly certain that they are threaded in.
  12. fatboy
    Jul 1, 2003
    290
    Tennesse
    they sure are!!!!! well got it out :D drilled a hole down it and got a nice easy out and did a bunch of tapping and drilling and out it came. woohooo
    thanks for all the info :grin:
