Steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flyinhi86, Jun 3, 2001.
  1. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    My steering seems to wander somewhat. I have 35's with a 4" lift. I have dual steering stabilizers. What can I do to stiffin it up.
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Do you have the steering box brace kit? If not, it should tighten it up a bit. It's not very expensive.
    <font color=red>I'm a psychic amnesiac. I know in advance what I'm going to forget. </font color=red>
  3. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Jason,
    Go to Main Index and then look for aftermarket products. There you will find a great place to spend money... Off Road Design. The steering brace that muddin mentioned will help correct frame flex that is an inherent problem on the K-5. If you run the tires and lift you will subject yourself to a cracked frame. If you already have a crack ... use the search button to check out where this occurs ... near the box. If cracked ORD makes a brace kit for cracked frames.
    Good luck!
    PS if not cracked get the brace, but you may have something else loose in there!
