steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Oct 3, 2001.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Ok. I got rid of the play in my steering. Now another delima.
    When turning to the left, it takes 3 turns of the steering wheel before it stops. To the right takes only 2 before it stops. What gives?
  2. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    hey,
    how did you get rid of your play? I have that same problem.
    Thanks, Ray
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i fixed mine by disconnecting the steering arm straighting the wheel then connecting it back
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    that is a draglink length issue.
    shorten it i think.
  5. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Drag link might fix this.. What I would do is undo the drag link, adjust the steering wheel to where you can turn it the same distance both ways. Then re-attach the draglink. There were some posts earlier about steering. One of the posters knows his stuff. I'd look for his posts and see if your answer is there.
  6. michaelm
    Feb 2, 2001
    872
    that wouldnt work
  7. dyeager535
    26,982
    191
    First thing I'd think to do, is get the front wheels on center. Then make sure whatever direction the pitman arm is SUPPOSED to face when correctly set up, that it i in that position. If it is, then adjust your draglink.
    IIRC, the pitman on the trucks can be put on any way you want, so centering the box would be necessary (find centerpoint) then make sure the pitman is facing the right direction. So I'd think: box on center, pitman on center, wheels on center. Adjustment to steering wheel after all of the above is met, would be at that point, through the drag link.
    What do you 4wd steering gurus think of that? Correct or way off base?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I just had to do this last night since the lift and new axle screwed up my steering. Disconnect the drag link and then center the wheel, adjust the link and replace it. Good as New.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  9. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    Thanks yall. Guess I will try that stuff this weekend.
    Ray......this is a site given to me in another post I had about steering, it explains the slop problem.
    <a target="_blank" href=http://www.monte-list.nu/tech/boxmesh.shtml>http://www.monte-list.nu/tech/boxmesh.shtml</a>
    Hope this helps.
