Steers real goofy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Jun 24, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Today I fired up the 87 K5 for a quick ride in the country. It had been sitting since Memorial Day weekend and drove fine then, but today it shot hard right if I took my hands off the wheel. What the hell could have happened while it was sitting dormant for a few weeks?
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Well, get Goofy out of the driver's seat, leave him at home next time.
    Could be a flat or low Rt side tire.
    Twiztid
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    awe, you are SOOOO funny... LOL
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    yeah, I was kind reaching on that one. Sounded funny at the time. Can't knock 'em all outa' the park. (I'd just like to get them out of the dimond once in a while)
    Twiztid
  5. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    were you wheeling it,,
    Never been stuck, just temporarily delayed.
  6. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    check your right side brake. the caliper might be sticking.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I would agree with the caliper sticking. If the tire was low, you probably would have noticed it. I would definitely ceck your calipers.
    85 GMC Jimmy, 305 w/TH700-NP208, 4" lift, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  8. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I third the caliper suggestion. Jack it up, pull the wheel off, see if the rotor spins free and smooth (unlocked). If not, open the bleeder a little with no pressure on the pedal and see if the caliper releases at all. I had the caliper feed hose collapse on a Camaro once, which would allow pressure into the caliper, but not out. Hose and caliper are probably pretty cheap to replace, just a hassle to bleed the system afterwards.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    ya, check the caliper or you may have debris in-between the pads... Also, the rght side tire may be low.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  10. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I second both the tire pressure and caliper ideas.
    Ben 87 Jimmy
  11. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Thanks for the tips and the abuse. I'm new here but I already feel right at home.
