Step 2: Truck Blazer
Discussion in 'The Garage' started by mountainexplorer, Apr 30, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    In less than 2 weeks, this is supposed to be roaring through a mud pit on 39.5" Boggers powered by a 396. From now until then I have 3 available days to work on it. All I can say is I hope I stay motivated.
    Needs:
    Replace throwout bearing sleeve
    Weld crack in frame (done today)
    Drill and extract broken off bolts in Dana 60 housing
    Buy clutch and replace flywheel ring gear
    Assemble remainder and install 396 with all accessories
    Somehow fit the full 3" dual exhaust system into place without cutting or welding
    Put front nose clip back on
    Fire it up and break it in
    Change tires, mount 39.5" Boggers on 12" wide aluminum rims
    Bolt rear seat and seatbelts in
    Put a rear bumper on it (optional)
  2. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    good luck and let the force be with u
  3. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    good luck! thats a lot of work to be done
  4. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    i know what your going through man, i have to swap motors, tranny, transfer case, axles, suspension, and build a winch bumper in like 3 weeks. with only 2 days off a week and a funeral to go this week. its not looking promising. but i hope yours goes better than mine. :waytogo:
