Stephen a question on T/R beadlocks
Discussion in 'OffRoad Design' started by spaceboy, May 14, 2002.
  1. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    I plan on purchasing a set of 15X10 Trail Ready beadlocks from you in the next month or so. Is there a waiting list on these or can I get them right away? Also I wanted to know about the back spacing for them. I am running a D60/14FF. What back spacing should I order them in in order to keep grinding to a minimum? I heard that 3" requires none at all. Am I right?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Availability varies, sometimes we can get them immediately, sometimes it takes a couple weeks. They generally try to keep the common stuff in stock so 15x10 8 luggers shouldn't be too much of a delay.
    We've seen backspacing up to 3.5" work out with some grinding, usually pretty minimal. 3" may require more of what I would call sanding on the caliper. Anywhere from 3" to 3.5" would work fine without severe mods to the caliper and bracket.
