Stephen, cross over steering???
Discussion in 'OffRoad Design' started by 90blzr, Jul 19, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    So what all do I need to get the cross over steering done. I have a D 60 coming that its going on. I know I need a 2wd steering box. I was told that I dont use any steering components that the lift companies sell is this right? Any pics anywhere so I can see exactly how it is set up, unless you want to explain [​IMG] I could also give you a call if that would be better.
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    <a target="_blank" href=http://coloradok5.com/crossoversteering.shtml>http://coloradok5.com/crossoversteering.shtml</a>
    you could start by reading this article and resting comfortably in the knowledge that the D60 has an even simpler design to add a pass side steering arm. i was just quoted $100usd for a custom made one. the rest of the article is everything you need to know
  3. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    You'll need:
    2wd steering box, or at least a box with a 2wd shaft
    Pitman arm
    Steering arm
    Draglink and ends
    That's about it!
    We can supply all but the steering box for you, I don't have pics yet since we don't have it all polished up as a kit, but it's not far off. our arm is tapered to fit a big GM tie rod end.
    Making the world better, one truck at a time.
    SW-ORD
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Hello Stephen,
    Two questions about the steering arm that you offer:
    Is the arm milled off on one side to alleviate the tie rod binding
    issue and what is the price?
    Thanks, Todd
    thebigdaddyof2
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Ok, so if I get a steering box I can just call you up and you'll take care of the rest of what I need, huh? Sounds good to me [​IMG] Any idea on a cost for the "kit" yet? I thought I remember your dad saying $300, but I could be wrong, it was a while back. thanks for the info guys!
    Oh yeah and you cannot run the sway bar, correct? Any chance of that happening for better on road performance?
    And do you have to make any crossmember mods????
    <P ID="edit"><FONT class="small">Edited by 90blzr on 07/20/01 10:49 AM.</FONT></P>
  6. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Yes, the arms are milled to remove the kingpin axis inclination (ends should run flat in most applications). They have the spring cap built into the arm also and will use the factory studs to bolt on the knuckle. Cost for the arm alone should be about $185-$200.
    We're going to try out a slightly bent draglink to avoid crossmember mods. I'm not fond of bending steering linkage, but it does work and will create a cleaner kit than having to fab and install a crossmember.
    Price will likely be $400 to $450, just a guess right now, but within $50 I hope.
    SW-ORD
  7. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    So how long until you think it will be available for all of us?
  8. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    We're starting to ship some parts now. Time frame on a full kit with the draglink and all shipped together is still a couple of weeks out, along with full production, but it's all coming together pretty nicely!
    SW-ORD
  9. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    What's the difference between your kit and the one that Shawn did?
