Stephen - do your rear discs really stop any better?
Discussion in 'OffRoad Design' started by Eric M., Oct 28, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    Oakland, CA
    This probably isn't the best place for this post. I've done searches regarding rear disc conversions and am getting too many different answers, so I thought I'd ask you. Here's what I know (or think I know).
    Rear discs are good for mud running (no drums for mud to build up in).
    E-Brake set up (Caddi calipers) don't hold as well as stock drums.
    You need to occasionly adjust the rear E-brake calipers.
    On most vehicles, the rear brakes only do about 30% of the stopping. So, there would have to be a heck of an improvement before it would really be noticable.
    I don't run mud and it is important that I have a good functional parking brake. I'm thinking that unless there is a noticable difference in stopping ability, I should just stick with the stock set up. Was there a noticeable improvement when you went from the 14 bolt FF drums to discs?
    Thanks in advance .... sorry for the long post,
    Eric M.
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    Nope. I had to have a proportioning valve on both setups, factory drums and the discs. Both would lock up the rear WAY before I wanted it locked. I went disc since it was cheaper than rebuilding my drums when they wore out, and it's lighter and less mud and sand sensitive. If you want a good parking brake and don't have environmental concerns (mud), the drums work fine. If you do need better drum brakes, you can get into the 1-ton 13x3.5" drums and they'll stop any K5 ever built. People will probably give them to you!
