(Stephen) early and late versions of NP203 for doubler?
Discussion in 'OffRoad Design' started by harry, Mar 13, 2001.
  1. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I understand the early version on the 203 is less desirable for the doubler because there are a couple of extra bolts that will interfere with your custom plates. Do you have a picture of each so I can visually understand what I am looking for in the junk yard?
    thanks, harry
    69k5
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We're going to modify our plate to where it will work with both the early and late 203's. There's just 2 different bolt holes between the range box and chain case, and it's not hard to modify any of the plates to work with the earlys. We'll just poke a couple more holes in the adapter, and if you fill them up with bolts, fine, if not, they'll just sit there.
    Making the world better, one truck at a time.
    SW-ORD
