Stephen need help.....Skyjacker softride 4" frt springs...need bushings
Discussion in 'OffRoad Design' started by 88jimmy4x4, Jan 28, 2004.
  1. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Stephen need help.....Skyjacker softride 4\" frt springs...need bushings
    Stephen, I currently have the rough country springs and they took a 1-1/2" greasable bushings. I just bought a set of skyjacker softride 4" front springs and measured the ID and its 1-1/8"....does this sound right?
    Could you please just sell me the 1-1/8" bushing set that I will need to do both springs?
    I can still use the same bolts and insert right?
    I also have the ORD front HD shackles with greasable bolts.
    Just please lemme know what to say or order when I call tomorrow (part numbers).
    JB
  2. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Re: Stephen need help.....Skyjacker softride 4\" frt springs...need bushings
    Ready to place an order....need the info please
  3. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    /forums/images/graemlins/1zhelp.gif
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Ok, sorry for the wait, it's been taking me a while to get to the top. You need new bushings and sleeves, the bushings have a different inside dia. so they use a different sleeve. The bolts will be the same. New main eye bushings and sleeves will run about $17.00. The HD shackles should work just fine.
  5. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Okay, so when I call and talk to the lady on the phone...what do I tell her I need....part numbers?
    You sure the hd shackle bushings are 1-1/8 dia, I dont remember?
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Just tell here what you're doing. The numbers you'll need are:
    4 - MO2052
    2 - main eye sleeves for SL/SJ springs
