Stephen - on using the 16.5 TR beadlocks?
Discussion in 'OffRoad Design' started by azblazor, May 31, 2002.
  1. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    How low of a pressure can you go and has the inner bead ever come off??
  2. azblazor
    May 5, 2001
    1,953
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    This <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=ord&amp;Number=325656&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>post</a> has some good info from Stephen on the air pressures.
    BIGJ
  4. azblazor
    May 5, 2001
    1,953
    Thanks Jeff,
    So according to that thread 7-8 rocks, 5-6 snow, and "has not had any problems" probably means he has not lost an inner bead.
  5. BIGJ
    896
    Central Arkansas
    That's what I thought too. I have had mine down to 6 in the rocks and haven't lost a bead yet. Doubt I'll go lower that that too, the tire was flat enough to conform to just about anything on the trail at 6 psi. If you want TR's plan on waiting a while. Mine took about 2 1/2 months to get here. They are well worth the wait though.
    BIGJ
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, that's about it.
