STEPHEN!!! pre-'85 and post '84 np205 t-cases *DELETED*
Discussion in 'OffRoad Design' started by thatK30guy, Aug 19, 2002.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    STEPHEN!!! pre-\'85 and post \'84 np205 t-cases *DELETED*
    Post deleted by thatK30guy
    Guess this idea is not gonna work since no one replies as to if this idea would have worked or not. /forums/images/icons/frown.gif
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Re: pre-\'85 and post \'84 np205 t-cases
    Good question, Wes. As you know, I have a 32 spline long input shaft 205, so I'm definitely interested.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I know I would be interested in a Doubler for these t-cases, too.
    I have 3 of these long input shaft 205's here. /forums/images/icons/shocked.gif
    I only have 1 of the short input shaft 205. /forums/images/icons/frown.gif
    These shorter inputs are harder to find, IMO, and just about every salvage yard I call has the long input. /forums/images/icons/tongue.gif
  4. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    This might sound like a dumb question but why not just change the input shaft to a short one ???
    I reread your question, I thought they do make the doubler with the round chevy pattern also.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Its like I said above....the short inputs are getting harder to find and no, I dont want to shell out so much $$$ for one either. /forums/images/icons/tongue.gif
    Where did you see that they make the Doubler for the long input 205's? I have not seen anything yet.
  6. j20m715
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Is there a round pattern short shaft & a round pattern long shaft t-case ? Maybe I'm thinking of the dodge doubler with the round pattern.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, the '85-'91 205's are a round pattern with a long input shaft.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: STEPHEN!!! pre-\'85 and post \'84 np205 t-cases
    Stephen, what do you think?
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: STEPHEN!!! pre-\'85 and post \'84 np205 t-cases *DELETED*
    Well, I guess this idea is not gonna work since no one replied. /forums/images/icons/frown.gif
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Not sure what your original question was since it's gone now but I'm assuming you're after a Doubler for the round pattern long input. Don't hold your breath on that exact application. We'd have to build an adapter about 3" longer and that's not possible the way we're building them now. The way to get what you're after is to replace the input with a short input, we sell the gear alone for $140 with a Doubler kit and it's a direct drop in replacement. Then we sell you a standard round pattern Doubler kit and you're done.
    Length is critical for most of the applications we put Doublers in so we have eliminated all but the shortest and strongest kits.
    Let me know if this isn't what you're after.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, that's what I'm looking for.
    I find the '85-'91 np205's dang near everywhere I call when I'm searching for a pre-'85 np205. Seems like the older ones are getting more rarer, so the newer ones are popping up more and more now.
    I can have a 3" spacer made no problem, but what is this round pattern Doubler you already have? I assume it's for the Ford or Dodge? If so, I can get one of these and have a spacer made to go ahead and use my current '86 205?
    I understand completely about swapping the long input for the short one, too. Just a little harder to find these short inputs. /forums/images/icons/laugh.gif
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We actually build an adapter specifically for the round GM 205, with a swapped in short 32 spl. input gear. We do have ford and jeep versions adapters, but that's not really pertinent here.
    You can space it out to save the long input gear but I think you're going to cause more problems than it's worth. A spacer will have to cost a decent chunk, you'll need longer studs (or really good allthread), and you'll have more pieces and leverage over them. I think swapping in the short input gear and keeping it all short would be the way to do it. The gear is about a 1 hour drop-in, and you're ready to go.
  13. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    My truck's an '85 w/205. Is there a serial number, or build date which will tell me for sure whether I have the long or short gear before I take it apart?
    Eric
  14. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    To the best of my knowledge if you have a short adapter than you will have the long input gear along with the round pattern 205 . The short input was only used in the older figure eight adapter cases .
    These guys will know for sure if I am wrong .
    Tom
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Typically if you have the round pattern case, you have the long input gear, that's the easiest way to tell. I suppose there are some crossed up cases with short inputs and round patterns out there but the stock setup was round pattern = long input gear. You can check the bolt pattern on the front of the case externally so that should give you a good idea what you've got.
  16. elacruze
    Dec 23, 2003
    121
    SE Michigan
    Drat. 1-7-85, and it's round pattern.
    Nothing worse to do than a shaft change? The trans/case spacer is about 4 inches long.
    WTF did they change this for?
    Eric
  17. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    And I dont think you are going to be able to buy a one off 3" adapter and related hardware for less than the $140 short 32 spline input gear that ORD sells. The long 32 spline input gear uses the same bearing as the short 32 spline input gear making it a drop in swap with no machining of the case if I am reading this correctly.
  18. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    OK, the short input is a direct swap for the long input, no machine work, no changing bearings, nothing, you'll need a couple of gaskets and the gear, that's all.
    We rank the desirability of a 205 for the Doubler like this:
    #1: Pre-85 fig8 pattern short input gear (factory TH400 version) - no parts swapping cost at all
    #2: '85 and newer round pattern with long input (factory TH400 or SM465 version) - Swap cost is a new input gear and a little time to swap the gears.
    #3: 10 spline or 27 spline NP205 - swap cost is input conversion ($200) + machine cost, plus time to completely disassemble the case and put it together.
    Why did they do this? I think it was to make the 205 interchange behind the TH400 without having to have 2 different output shafts in the 400. Also, the same 205 works behind the SM465 from that era using the same output shaft in the SM465 as a NP208 would use. Basically it streamlined the transmission and transfer case ordering, assembly and inventory. I wish they'd gone to a round pattern from the start, it's a good bit easier to deal with in just about every way.
