Stereo draining my battery?
Discussion in 'The Garage' started by Mastiff, Nov 19, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    It seems that my battery runs down if I don't fire the truck up at least every week or two. I'm wondering if it's related to my stereo install. When I did it, I was under the influence of some stereo-philes who suggested I run all the power direct from the battery (not keyed). So I can run the stereo with the key off... thing is, I wonder if there's extra current being drawn while the truck sits around? I tried pulling the fuse and sticking my amp-meter across it with everything off. It said 0.01 amps. I'm not sure if I trust the measurement, but would that be enough to cause trouble? Any opinions out there?
    I'd hate to rewire this thing. Getting access behind the stereo is torture on these vehicles! :doah:
  2. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    my stereo is connected directly to the battery it has a red LED light that stays on all the time and the battery will last for a few weeks that i know of.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    either something drawing power, or as i found out, i had a bad cell in my battery, would not hold power for more than two days.
    bought a new one, been workin fine ever since. :D
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I have wired my stereo like yours and If I leave the face plate attached it will discharge the battery. If I had run the wires correctly, I could just turn the ignition switch to the accessory position to run the stereo. :doah: I'm sure I'll get around to it in the next couple of weeks... :wink1:
