Stereo Questions
Discussion in 'The Garage' started by 87K506, Mar 4, 2007.
  1. 87K506
    87K506 1/2 ton status
    Sep 18, 2005
    536
    Pitkin, Colorado
    I'm tryin to gather up info for my upcoming build on my k5, and since this is the only place i can post right now (paid membership will be coming soon). What is the largest speaker you can fit under the dash correctly? I mean stereo locations. I can modify the speaker brackets to hold larger speakers, but I'm tryin to figure out how big i can go without it hitting the dashpad, or pushing on the dashpad.
    Cory
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i cant tell ya but i have 4 inchers laying on top of the gaping holes where the speakers used to be.
  3. 87K506
    Sep 18, 2005
    536
    Pitkin, Colorado
    yeah i figured 4 inchers would work in the speaker brackets with some modifications, but im worried about goin bigger than that and hitting the dashpad cause im buying a new pad
  4. bigblaza
    bigblaza Registered Member
    Jan 16, 2007
    65
    Maryland
    well Im working on my build right now and Im not even using the stock speaker spaces...even if you put 4's in there you're not gonna get much from them...I would put 6.5's components in the door and use the stock spaces for tweeters. I couldn't find 3.5's that sounded worth puttting in there. but thats my opinion...
  5. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    I've got 6x8's in the doors, and will be replacing the dash speakers with 4" Polks or Pioneers. Anyone know what the size is of the center dash speaker in a '87 K5?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I put 3.5 inch Soundstreams in mine , they are crossed over , so no bass goes there . Sound great for the frequencies that do go there . You will need to cut the metal bar under it for anyones 3.5's with tweeters to fit .
  7. bigblaza
    Jan 16, 2007
    65
    Maryland
    I believe it is a 5X7...I toyed with the idea of putting a speaker years ago when I first got my blazer...but I couldnt find a stereo store that stock a speaker with those dimensions...
  8. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Okay, thank you. I just figured when I replace my dash I should replace the speakers while I'm at it, along with an amp for the speakers.
  9. 87K506
    Sep 18, 2005
    536
    Pitkin, Colorado
    I'm trying to stay away from cutting the doors up or anything...So I want to put speakers in the stock locations. I think I am going to go with a dashpad cover instead, So I think i can cut the pad away for the speaker to work, and then still have the cover go over the stock openings...if that makes sense
  10. bigblaza
    Jan 16, 2007
    65
    Maryland
    I hear ya on that. I was going for more sound so thats why I went in the doors.
  11. 87K506
    Sep 18, 2005
    536
    Pitkin, Colorado
    I think i'm gonna have plenty of volume...and the frequency responce should be ok... The current plan is 4" in the dash, 6 1/2" behind the front seat/infront of the rear seat, and 6x9's in the back with 2 RF 10" subs in the sides of the cargo area in custom boxes...should sound pretty bad ass
