Stereo woes..
Discussion in 'The Garage' started by SS66, Oct 7, 2006.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I just got a new stereo and hooked it up.................. it powers on.. everythhing works for a few seconds..then it powers off.... and starts right back up. All the wires SEEM to be in order but obviously something isnt right..
    Anyone have any ideas as to what it might be?
  2. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I checked the volts, the acc. wire is 12v... the constant hot was only 3v for some reason.. So I found an empty terminal on the fuse box..tapped into there.. have 12 volts on BOTH wires.. and now it wont power on at all. I checked the fuse on the radio and its fine... The ground is good... I dont know what else is left?
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Sounds like something got hurt with the low voltage... Sure you checked all applicable fuses?
  4. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    It's hooked to the blinker... :haha::haha: I kill me!
    Seriously, check the radio for proper function. pull it out and go hook it directly up to the battery. make sure it works.
    then, check your constant hot for current. make sure it's not on a low current circuit. the acc wire only needs to be a few mA but the power line should be a couple amps. even better, go out and get a wiring harness for it. then it will use all the factory wiring. for our trucks, its 3 plugs i think.
  5. TheToolmaker
    TheToolmaker Registered Member
    Sep 3, 2006
    9
    Indiana
    Also make sure you plug an antenna in when you are testing it. For some reason some radios won't work without an antenna hooked up. Good luck!!!
