Steve-posted pictures of Dana 60 steering arms
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by titanic, Sep 16, 2001.
  1. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I finally got around to posting a few more pictures of the steering arms we talked about-sorry I didn't get to clean them better,pressure washer just doesn't get all the mud.<a target="_blank" href=http://www.tennessee4x4.com/rocketcity/titanic.htm>www.tennessee4x4.com/rocketcity/titanic.htm</a>
  2. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Ummm could I get some details on that? Is that steering arm home made? How excactly did you put the tie rod over the spring? Its nott he first time I have seen that done. Now I am getting curious. Also what kind of ram is that? Where did you get it? It doesn't look as bulky as most others, does it work as well? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    OK, now I understand, thanks
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    I believe when titanic had his custom springs made he ordered them with the center hole moved forward 1-1/2" otherwisw you would run in to clearance problems with the pitman arm.
    Steve
    Steve
    Bandwidth FREE ZONE
  5. titanic
    Mar 27, 2000
    498
    dawson-The steering arms are made out of 1" steel plates, the spacer blocks 1.75" high were made like a dana 60 steering correction block only shorter and I welded these two together along with two 1/2" steel plates on the inside /outside of the steering knuckles so the ram would not push only against the 4 studs holding the pieces to the knuckles. I had Georgia hydraulics make that cylinder for me-I needed one that had a 10" stroke and have attachments like that for the way I wanted to mount it. Steve's right on my springs-they moved my front axle forward almost 2" so I can clear the pitman
