Stick welder
Discussion in 'The Garage' started by 84gmcjimmy, Jun 6, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, I was wondering what a good stick welder is? And what is the price range for a good one? I will be wanting a Miller or Lincoln only, because that are the 2 best known names /forums/images/graemlins/thumb.gif Any help is good /forums/images/graemlins/bow.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the ac255 lincoln is a great machine and cheap, they have been around forever. the one we have, my dad used as a kid, and it still works great. /forums/images/graemlins/waytogo.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Really a stick welder is pretty much a stick welder. They mainly differ in duty rating and power. I have a 30 year old craftsman cheapo stick welder and it has never let me down. I always suggets going for the options you want first and brand name second.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    How come when I am looking at them they don't say how thick of metal they can weld? Just a bunch of the amperage numbers and whatnot /forums/images/graemlins/confused.gif?
  5. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Because unless you are welding 1/2" or thicker plate it really doesn't matter. My 180A welder has welded everything I have needed it to from 1/8" angle steel to 1/2" plate (the 1/2" plate took multiple passes to fill the V notch but it is still holding as a repair to our backhoe to this day). I only change the amperage if I am welding thinner metal and I know at a higher setting it will burn through.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oooh okay. Do you have any suggestions on what model I should get? It seems you know what your talking about, so you can help me /forums/images/graemlins/laugh.gif Thanks
  7. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Actually everything I know is from 10 years of trial and error and reading welding books. I have only owned 1 stick welder and I discovered it in the basement of one of the cemetery buildings. It's a craftsman buzz box 180a stick welder that is older than I am. I know nothing about other welders. The main things I would look for is duty cycle, amperage, and cable length. If you aren't going to be welding hard core a 20% duty cycle should be plenty, it's what mine is. I wouldn't buy a stick welder less than 180a, 220a seems to be the sweet spot. And make sure the cables for the ground clamp and electrode holder are long enough. I hate having to weld something and the cable doesn't reach.
    Incidentally I still use that stick welder. Between it and my 110v gas mig welder I haven't met a project I couldn't finish with my equipment.
  8. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    ac255 lincoln
    [/ QUOTE ] I have the same machine. I bought it used for 150. It works great. I can weld anything I would ever mess with. What are your intentions with a stick welder? Why not go with a good millermatic mig or something of that nature? Then you can weld thick or thin.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Scoutillac, I already have a Millermatic 135 MIG welder, so I can use that for thin stuff, then instead of buying another MIG welder, I thought a Stick welder would be good for bumpers and thicker metal /forums/images/graemlins/thumb.gif
    Rootbreaker, I like the sounds of that welder you have. How do you like it? I also like the price compared to some Stick welders I've seen /forums/images/graemlins/eek.gif
  11. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Re: Stick welder *DELETED*
    Post deleted by ugly_blazer
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I just read the specs again, and Lincoln said they can only weld up to 3/16" metal, which is the same as my MM 135 /forums/images/graemlins/dunno.gif /forums/images/graemlins/doah.gif
  13. ugly_blazer
    Apr 12, 2004
    1,214
    I have a Lincoln AC225 that I bought new for $239.00 and it does a great job. The AC only model will probably do just fine for you as opposed to an AC/DC model. I like stick welders because I am lazy and don't clean rust, paint, dirt, etc... from metal very well, but the stick blasts right through it /forums/images/graemlins/grin.gif
    Lincoln at Lowes
  14. ugly_blazer
    Apr 12, 2004
    1,214
    I can burn through 1/4" plate with mine real easy, and it has welded 3/8 without a problem. On the site it says a 3/16" electrode, is that what you seen? /forums/images/graemlins/dunno.gif Electrode is the term for the stick, which would be 3/16" diameter.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    This is what I read :
    • 225 amp AC output is enough for 3/16" diameter general purpose mild steel electrodes and most 5/32" sizes.
    So the 3/16 part means the electrode? What sizes of electrodes is there? I am assuming, the smaller the electrode, the thinner metal you weld? You said you can weld 3/8ths metal? Do you think it could weld 1/2"? Thanks /forums/images/graemlins/waytogo.gif
  16. ugly_blazer
    Apr 12, 2004
    1,214
    I'm sure it could weld 1/2". I weld 1/4" on the 90 or 105 amp setting (usually 90) and it penetrates real deep. The settings of course go to 225.
    Here is a good Electrode Link to read. It tells of different amperage, rod sizes, and types of rod. I usually use an 1/8" 6011.
  17. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I have the Licoln AC225 stick welder that my dad used when he was a kid and it still works great. And I have welded 1" thick metal with it in a single pass with ease /forums/images/graemlins/thumb.gif
  18. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats what i said /forums/images/graemlins/waytogo.gif except the 1" part but i did do it, took 2 passes to fill the V though.
  19. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    1" with one pass? What kind and how much rod did you use? You didn't weld a full one inch thick weld did you? And aren't you "suppose" to cover pass with two beads over one and 3 over 2 and so on to fill that deep of a groove? I need a to see a pic of a 1 pass 1" deep weld with a stick welder to believe it.
  20. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Indeed 1" with 1 pass is not feasable with a 225a welder. It will not penetrate 1" deep. You would need to make a groove so your plates look like this when they meet \/ then you use multiple passes to fill that groove. I have done this exact weld on 1" thick plate.
