Sticky Adhesive
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, May 31, 2002.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    What did ya'll use to remove the adhesive on the back of the wide silver pin stripe on the side of ya'lls K-5. I'm trying not to damage the paint. Thanks /forums/images/icons/smile.gif
    Eat More Mud!
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    heat gun..and be REAL careful! That's we used when I worked in a body shop a number of years ago.
  3. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    You mean the metal/rubber side trim? Use a hair drier or heat gun to soften the adhesive before you attempt to pull it off (no pun intended). Same process as removing those annoying dealership emblems.
    Might want to give this idea a second thought though, as the paint underneath probably won't match the rest of truck because it was protected from sunlight by the trim.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    have you tried goof off that stuff works kinda well
  5. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    I use a product called Goo-Gone on my stuff and it works real good you can get it at walmart, or other places.
