Sticky Caliper...what to do?
Discussion in 'The Garage' started by rjfguitar, Mar 6, 2005.
  1. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Today I took the K5 for a spin and noticed it pulling to one side, I flipped around towards home because I figured a rear drum was hanging up. When I got home it was a brake but it was the passanger front disk and it was smoking a little. :eek: Is there anything I can do to get it to unstick itself and quit hanging up? My dad mentioned it is probably gotten rusty from all the mud and water that has been all over it all winter, and from the lack of driving it.
    I have the tire and wheel off, is there anything I can do? :dunno:
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    As cheap as they are I'd just put in a new caliper, theres nothin to realy do if its stickin. I had both of mine do the same thing I figured if I pressed the pistin all the way back in it would free up, nope. lol. I ended up puttin 2 new loaded calipers in.
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'd get a new set of calipers and slap them on. Probably not what you wanted to hear. Otherwise rebuild them.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hey dude, why don't you take the calipers off, and clean the two sliding pins the calipers float on, you might even want to put a little grease on there so the caliper will float and not stick like you are describing. Bet its just a bunch of mud and rust keeping the caliper from floating back and forth when you step on/ let off the brakes.
    The same thing is going on with my sisters suburban and i'm about to go try and fix that...
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would guess a bad brake line (hose) from the frame to the caliper. When it sticks - loosen the bleeder screw, if fluid shoots out it is probably a bad hose. If no fluid shoots out and it is still stuck, probably a bad caliper. It makes more sense to troubleshoot the problem rather than just throwing parts at it.
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I highly doubt it's a line since I have stainless steel braided lines but I'll check it.
    Ryan,
    I'll try your idea and see if it works or not. :D
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Im willing to bet its exactly what Ryan said, as i had the same problem. Truck sat for 10 days after just being wheeled and driven home 120miles in the salt and when I got home 10 days later it had a froze caliper. I drove it home, parked it, and left for the airport in a taxi. Got home and it was pulling to the right and then pulling left when i hit the brakes hard. Hit the pins with PB blaster, and threw a little teflon trailerball grease on it and they have been fine since.
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Well I loosened the the bleeder screw like Divorced said and no fluid came squirting out. I guess the stainless lines are out. I then took the caliper off and cleaned it the best I could like Ryan said but I tried to push the piston in but it wouldn't budge.(the bleeder screw was loose to let the piston compress) I took it for a drive again and it seems to not be as bad, wants to hang up, then release but I don't think the caliper is working very well since when I stomp on the brakes it pulls hard to the side that is working properly.
    I think I should probably break down and go get some new calipers. I'm kind of trying to patch a bald tire it seems. :o
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Cheap at the zone...
    The brand new calipers on my 82 diesel were seized the first day I got it roadworthy!--the previous owner bought new ones,but the truck sat for nearly 2 years before it was on the road again,they seized up!--I tried cheating and lubing up the slides and pins as suggested,but I'm never that lucky-:frown1:
    -so after I made sure it wasnt bad rubber hoses(judging by how hard I had to crank the "C" clamp to push the pistons back in,it was a no brainer they were seized!)--I took them with me to auto zone,so I could exchange the cores and match them up,I went home with 2 rebuilt calipers and a bottle of brake fluid for about 25 bucks!--11.99 each for the calipers-since it was so cheap I sprung for new disc brake pads ,they cost more than the calipers!.:crazy:
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    time for new calipers, they are only $16 each, here anyway.
  11. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Oh common , there only 16 bucks for heavens sake ,, go and buy a new one :p: :grin:
  12. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Once upon a time this happened to me.... thought it was a sticky caliper, replaced both of them just cause, didn't fix it :confused: . Turned out to be a TINY crack in my cheapo Albany brake pads, which put half the pad or so in just enough contact with the disk to smoke the brakes. Just look at the pads VERY closely before you head to the parts house.
  13. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    replace...
    $13 at advance auto parts here
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I'm going to replace the calipers. :)
