Sticky Clutch Pedal
Discussion in 'The Garage' started by drofdar, Sep 25, 2005.
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    My clutch pedal on K20 does not return all the way up after shifts. I have recently replaced the clutch and pressure plate, but it still does not come all the way back up. The under dash spring seems to be ok. And both springs for the linkage underneath seem to be ok also. Major pain as sometimes the pedal stays all the way down. Any ideas?
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I had a similar issue with mine after new clutch /pp.The BIG over center spring under the dash was the culprit.I removed it and no worries,also installed new bushings in the pedal assembly.
  3. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    Clutch Pedal
    So, you just removed the large "overcenter" spring under the dash? But did you replace it, or just leave it out? I thought that was what pulled the pedal up all the way after the linkage reached the overcenter position. My spring seems to be ok. Where did you get the bushings? Thanks.
