Sticky door locks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Dec 27, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Sometimes when I turn my truck off, the door lock on the driver side doesn't unlock. I have a security system in it, and the door lock automatically when I turn the ignition and unlcok when I turn it off. Sometimes they just move a little and don't come up. When I use the key to unlock them, its fine. i think something is wrong with the linkage. I greased it really good when I had the door panels off last, but I don't know whats wrong...anyone?
    90K5
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check your security systems electrical connections and also see if there is any binding inside the door might be just enough to stop the auto looking but not enough to affect you using the key
    s.smith 77blazer lookin 4 mud
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Sounds like the solenoid/door lock motor is sticking. Not sure of the fix, sorry, but that symptom has happened in the past with one of my earlier rigs, actuated by the alarm. The alarm only "tells" the door lock solenoid/lock mechanism to fire.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  4. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Mine did this after changing lube in the locks/latches. Use a good lithium grease on the actual lock mechaniasm.
