sticky throttle on TBI? help
Discussion in 'The Garage' started by sled_dog, Feb 28, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What could be causing this? I stopped at a buddy's house and checked the linkage and all after it tached out when I went to shift between third and fourth. Couldn't recreate the problem manually operating the throttle. I'm used to the little bit of residual power TBI creates when you let off the gas, my 95 had it so does the burb but this is plain on stuck throttle. It happened again when I left his house between second and third this time. Maybe throttle shaft bushings? I don't think its a linkage bind. It just stops on its own, I don't even have a chance to kick the gas to stop it.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    That, or throttle cable sticking in the housing.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check your throttle cable. A strand may have broken and is binding inside the cable housing.
